1 - 3 of 3 Posts
The master on my 93 900SS is pretty cruddy. Slave is toast. Getting a new slave but wondering if the master from later (2000ish) app's work. Can't see why not, no?
Sent from my LG-H910 using Tapatalk
In 2000, the clutch master cylinder was changed from a 13x20 to a 12x19 configuration. Not a big change, but it did nicely reduce clutch lever pull force by 15%.
As a consequence, to avoid clutch drag, it is recommended that the 2000-plus 12 mm master cylinder should not be paired with an aftermarket slave cylinder size greater than 29 mm.
1 - 3 of 3 Posts
