1 - 3 of 3 Posts
Hi
My clutch system again leak air into system. After slave replacement for Oberon, now my master leak air.
Cant bleed air on master, cant bleed on slave, air is still here, clutch wont disengage full, hard to shift, when switch to 1st gear bike start to roll. Before several rides can bleed at master and for several miles air is in system again. Now cant bleed at all, spongy fill, pressure plate little move. Oil get darker after several days.
Is it on market any rebuild kit for 1098/1198 clutch master cylinder?:frown2:
Or some alternative which is compatible.
Thanks
1 - 3 of 3 Posts
