Easy question: I have a 2001 748 and am wanting to replace the clutch lever. After removing the lock nut and screw and pulling off the lever, the barrel clip has a small somewhat conical shaped part that fits into the control tubing. The conical part (which needs to be removed) is threaded but will not un-screw!
I'm afraid that I will strip the screw. Any suggestions? Thanks
