Hi guys
I'm looking for a replacement clutch lever for my '82 900ss rebuild, which is moving along nicely, and I've just made a post in the classifieds. I've also been emailing around and searching without any luck.
What I have found is this one:
https://www.eurobrit.com.au/store/Ducati+Bevel+Pegs+and+Levers/Ducati+SS-SD+Clutch+Lever
It's very similar to mine, but you can see how it has a squared off bit on the right there where mine is more rounded. Does anyone know if this is a possible replacement... maybe with some filing?
I've overlaid mine on the fuzzy image there and it really does look identical other than that edge, and I think there is also a small hole in the topside where the end of the cable sits.
Regards
Rob
Regards
Rob
