I was just performing the quiet clutch modification and when I had things apart, I noticed that I have some significant play between the clutch hub and the front sproket.
In first gear, I can rotate the clutch hub roughly 60° without any rotation of the front sproket. The amount of play reduces each time I shift into a higher gear. I would expect there to be some play to help ensure gear engagement, but is 60° typical?
The bike is a 2004 ST3
Thanks,
Flips21
