I was on a ride this past weekend. (Labor day) I ran into an interesting problem. My clutch hub nut came loose on me. I believe the torque setting is supposed to be around 140 ft-lb. The clutch lever pull started to feel light and then nothing. No power, no shift, etc. Interesting. I pulled over to the side and was able to get the clutch apart with the standard tool kit. I found the hub nut had completely came loose. I honestly cannot remember if I torqued it to spec. So I feel I am completely to blame. A nice by standard stopped and offered help. He was able to run home and bring back a 1 1/4" socket so I could tighten the hub nut. I was able to ride the bike home after about an hour on the side of the rode. I rode it home about 40 miles no problem. I took the clutch assembly apart at home and torqued everything to spec. I did ruin my clutch spring retainer though, where it rubbed against my clutch cover. All is well now it seems. Hope this does not happen again. What a PITA!
Thanks to all those that are willing to stop and help a stranded motorcycle rider.
Note to self: Make sure you tighten all nuts and bolts to spec.
Everyone ride safe, and thanks to those here that have taught me everything here.
