Anyone got a "pro" way to take off the clutch gasket, or wants to know my way to do it? Engine is Testastretta 939.
Thanks
Frans
Administrator
You will usually get a better response if you post under the respective forum for the bike you have.
are you asking how to remove the wet clutch cover on a 939 engine? undo the screws, tap it with a rubber hammer until it comes loose, then pull it off. some of the late ones might even have little tabs to lever off?
