I just noticed today that the clutch basket on my 999 wobbles a bit at idle.... My 900 or 916 doesn't do this, should I be concerned? Also, ridding to class today I noticed that with the bike in gear and the clutch pulled in the pressure plate slows and eventually stops, never noticed this before....
Discussion Starter #2
The999 has a STM slipper clutch if this makes a differance
The hub nut might be starting to backing off ?, would recommend you
check it A.S.A.P.
The pressure plate slowing and stopping is normal with
the clutch pulled in.
brian.
The hub on my 916 had some play in it, it was around 1-2mm further out than it should be, turns out the steel washer had 'eaten' into the hub and worn away some material so that the hub was able to move in and out.
Had a perfect washer shaped groove in the hub...
