1 - 11 of 11 Posts
Hello,
Anybody know the thread size of the clutch basket screw? The head is 13mm hexagon head.
Best regards
2000 M900Sie, 2003 Aprilia RSV Mille-R, 2x 1981Guzzi Monzas, IWL Pity, Piaggio Hexagon, PX Vespa
If it has a 13mm head, standard size would be an M8
Chris
You do not need to change these normally for what reason are you replacing one?
Keep in mind the rating of the bolt, I would only use a hardware store version in an emergency and then not anything under grade 8. You also need to loc-tite the bolt as the loc-tite also seals oil in the motor, if you put it in dry you will have an oil leak by the threads.
Torque should be about 35 nm
Discussion Starter #7
Yes, I am going to replace the clutch. I just worry about the original screw will be fatigue or become weak, therefore, I want to change the screw.
That's some serious bling.
1 - 11 of 11 Posts
