Getting closer to getting my bike back on the road (replaced oil gallery cyl. head o-rings, new fuel pump, rebuild carbs......) and find that I can't bleed either rear brake and clutch MC Both are original fitments.
Looks like the rear (10mm?) MC rebuild kits are availale on flea-bay but not much for the clutch.
A remote reservoir set-up/swap seems readily available but it looks like the carb choke lever is integrated into the MC. Right? Wrong? Any suggestions/guidance?
Much thanks.
Much thanks.
