desmo, install of closing rockers ? anyone got any tricks or tips ?
heads off on the bench
? :think:
? :think:
I'm not sure what you mean. The clearance can be measured between the rocker and top shim, or between rocker and cam lobe, no matter if the head is mounted to the cylinder or not.yep the heads are off. How Can I tell where to take the clearance measurements from , when the heads are off?
I installed a couple new rockers so clearances are all out.
What I meant was . what is the location or where is the rotation of the cam lobe. There is a pretty large are of the cam where the valves are all closed. How do I know where in that area to take the measurements ?
