I've set my dash clock and trip meter several times now and they always reset themselves to midnight/zero when i go for a ride...anyone else experiencing this problem?
I talked to the mechanic at the dealership yesterday, he told me to bring the bike in...i wonder, this is my brain talking, if there are two states of power. With the bike off, no power to the dash functions that require power. When you turn the ignition key on, power restored, clock and trip are once again cycled up.
First thing I would do is check the dash connectors to make sure they are fully seated / and or / unplug and check that no pins were bents. As a safety, disconnect battery before doing so. I've taken the dash off my late great ST3 with battery connected, but hey, why risk something.
To remove the dash, there are two 10mm nuts on the backside of the unit, lower portion. You get to them by turning the steering to the lock for each side to access. Then lift up on dash as it sits in two grommets with a pair of snaggle tooths. You don't have to remove the nuts, just loosen them. The dash slots into the bracket, very visible from behind the dash you can see the slots in the lower bracket.
If that is not the case (bad connection), then maybe you need to drop it off for repair/replacement. Dashes are not cheap! Hopefully if you do take it in, you can demo the fault... if it is doing it every power cycle of the bike being turned on.
Mine hasn't been fixed, it happened again twice 4 days ago and again yesterday...Mine was fixed at the 600 mile service, it was a loose connection...
I provided the dealer with the code when the bike was in for the 600 mile service...they found and fixed a loose connection and never mentioned the significance, or lack there of, of the code.That is not right.
1) bad dash (pins or faulty soldering)
2) bad dash plug
3) bad harness (power comes from where. relay? and ground?)
I would talk to the dealer about that code you said. Is that some sort of software revision# that is supposed to come up in the diagnostic mode?
In any case, cutting power and restoring it like that is not a normal thing, as long as you document it with them and see about them establishing a case under warranty, maybe they will say "ride it till it fails, we got you covered" or "we should replace that", they could at the least inquire with Ducati DNA or Bologna and see if this has happened to other like dashes.
I took my SF to the dealer on Monday.That is not right.
2) bad dash plug
