I had the SF's ears cropped at the dealership so the spacers on the front turn signals are GONE! Bike looks way better in IMHO. Also put some CNR levers on and some frame and axel sliders today as well. I still need to spray the bulbs silver to get rid of the egg yoke look.
**EDIT- The following instructions are reposted from post #21
Did mine too. Thanks
Below are the steps on how to.
Remove the hex screw at the bottom of the headlight
Loosen or remove the L/R nut that are holding the headlight assembly and lift up. You will see two hooks beside the gauge being held by a rubber grommet.
Remove the hex bolt and plastic spacers off the turn signals, replace the bolt with a shorter lenghth, resuse the triangular washer and you're done
