clear coating Carbon Fiber exhaust
7094 2
I am planning to take my CF termignoni (45/50mm half system) exhuast off 998 and get them clear coated. I want the protection from exposure to UV rays and water/soap, etc... I have a few question for those that have clear coated there exhaust or have knowledge.
1) Does anybody know if the termignoni CF is pre-preg? It seems not to be pinhole free? Or do they use a UV inhibitator epoxy resin?
2) Does anybody have insight to the process used by DP on the exhuast?
3) Does anybody know how high the temp gets on the CF when the engine temp is around 180 (bike has been running)? How about when it gets hotter 210?
4) Does anybody know at what temperature a general clear coat will degrade?
Or can someone recommend a high UV, high temp industrial grade clear coat?
5) How many coats of clear have people put on their carbon fiber exhuast?
I know some of the questions are pretty technical, but I am trying prevent my CF exhaust from turning yellow from sun exposure and when the bikes gets washed with water. Thanks in advance.
1 - 3 of 3 Posts
Administrator
I have DP exhaust (CF).
Here is what I did.
1)Scuff sand with 80 grit paper. Wet sand and only scuff it.
2) I used Sherwin Williams auto acrylic enamel (it has UV inhibitors).
3) I did 4 coats of clear.
The heat is not enough to cook the enamel and it looks great.
If you do not have a spray rig, then use Dupli-Color acrylic enamel in the sparay can.
It works well enough. And it also has the UV protection.
Need more details?
PM me.
1 - 3 of 3 Posts
