I read some of the other threads about the nice LED brake lights with the LED turn signals integrated, but I can only find mention of the Clear Alternatives version. Are there other manufacturers out there for an '06 800SS? If so, are they any good or is the CA model the best?
Also, assuming it is legal in my state of NH, where do people relocate their plate to after removing the entire rear holder? How do you secure it underseat or in that area?
Thx.
I don't know of any other options offhand, but I do know that Clear Alternatives products are hit or miss. Their quality control absolutely SUCKS. If you get one that works, you've lucked out, and it's probably fine, but chances are you'll have to return/replace it at least once...
Bump because I can't seem to find any other manufacturers other than CA
I e-mailed clear alternatives a couple of weeks ago to find out how bright their tail light was and have yet to read a response.
Be careful with LED tailights, the stock bulb puts out 40/400 lumens (tail/brake), I have yet to find an LED retrofit that hits those levels, the newer LED's like the Cree's other are larger units that will do it, the limit of LED's being near 1000 lumens now.
Here is a direct quote from the superbrightleds.com website concerning LED tailights:
Brightness of LED Car Bulbs
LED bulbs are generally not as bright as standard incandescent bulbs, they have many advantages over filament bulbs (longer life, faster on/off times, lower power consumption, more vivid colors) but brightness is not one of them. They are generally not as bright but some of them with large numbers of LEDs, will appear brighter than filament bulbs. As an exception, our new 3 Watt and 5 Watt Luxeon LED car bulbs are as bright or brighter than most standard filament car bulbs. The light is distributed differently so they can appear brighter in some applications and not as bright in others, it depends on the size and shape of the bulb housing and reflector.
Most LED bulbs emit light like a flashlight, all out the end. Regular filament bulbs emit light from the end and all sides, so they will be better suited for some lighting applications than LED bulbs. This is the same reason why we do not rate LED car bulbs in lumens or watts, the numbers would be deceptively low because the light is measured from all sides and the end on standard filament bulbs but only from the end on LED bulbs
