I am planing on doing my oil change on 2007 800ss.
Do I need to clean the oil filter screen?
How often do I need to do this?
I couldn't find any reference in the user manual, but the oil change tutorial I found said that I need to do it with every oil change!
I clean mine every oil change because it's relatively easy to do. Not sure about your year SS, but the early model takes a large 21mm socket to loosen it. I usually check for any large fragments, then spray it with some WD and wipe it off with a clean rag.
Duck:
Thank you for the info.
Anyone here with a newer model SS want to share his wisdom?
my motor is an 01 900ss and there exactly the same as the carbied version.
