Congrats! I have the same setup except for the quick shifter because I'm so damn slow these days, I just leave it in first gear.
Cruise control is great. Don't freak out when working with TB. Most here find it to be a little tricky, not all that intuitive, and a little short on directions,
but it works great. Here are some notes based on my experiences with it that may help when you get to that point ...
Notes for upgrading to TuneBoy Version 4.0 from an earlier one (2.0 in this case):
> Under Section 4 - Installing The First Map of the Version 4.0 instructions, you essentially skip steps 7 - 21 because you did those in setting up your earlier version.
> Close all TB programs if any are open.
> Connect the WB01 WiFi Box’s USB cable to the PC. Do NOT connect the WB01 to the bike at this point.
> Find the file WB01_Update_1_0F.exe in the TB folders that you downloaded to your PC. Right click on it and run as Administrator.
> Disconnect WB01 WiFi Box’s USB cable from the PC because you want that “WiFi/USB” light on the WB01 to be steady - not blinking. The USB cable causes interference.
> Pull the headlight light fuse to save the battery. (It’s the 1st one in row closest to front of bike on my 2012 MTS.)
> Connect the WB01 to the bike.
> Turn on the bike.
> Connect to the TB WiFi network on your PC.
> Right click the WB01 Find icon and run as Administrator.
> Right click the FlashMitsubishi icon and run as Administrator.
> Answer YES if asked to connect the WB01 via WiFi.
> Select upgraded tune (base map) and flash to the ECU.
> Turn bike off. Wait 30 seconds. Turn back on. See if it took by turning on TuneBoyTrim described below. Otherwise, try again. It may have to be done twice to take.
Notes for using TuneBoyTrim to turn off the Service/Oil Indicators:
> Turn on the bike.
> Right click the TuneBoyTrim icon and run as Administrator.
> Follow the TuneBoyTrim instructions from here.
