Okay thanks. The hyper can wheelie?
The compression and rebound are one turn out from full soft.
Maybe..........try going to a parking lot & hit a speed bump in 1st gear at 5000rpm, while sitting on the rear tail, then "wack it FULL THROTTLE" & hold it there, if you lucky the front might come up a little.Okay thanks. The hyper can wheelie?
I bet that's probably itYa know, the fork springs wind tighter at the very top in order to fit the fork caps securely. It APPEARS progressive but that section is not that functional really as it is only a couple of inches (60mm-ish) long.
Could that have been what he was refering to for the "progressive" wound part?
Dave
It took me reading it a few times to figure out what your numbers were but I think I have it now.Ok, so I'm wondering if my numbers are correct here.
I've setup the suspension so that the front and rear now simultaneously drop, so that there's balance in the frame. Both sides also simultaneously go down and come up(which they didn't initially).
I've upped the rear from 2 threads showing to 4 threads showing, the sag numbers on the rear are as follows:
static: 65,5cm(655mm)
bike on its own weight: 63,5cm(635mm)
bike with rider(me) on it: 61,5cm(615mm)
To me, these numbers sound about right, but are they?
These are the numbers for the rear, so for the shock.It took me reading it a few times to figure out what your numbers were but I think I have it now.
Are these front numbers (forks), or back numbers (shock)?
Because honestly, they are in the middle of where the front and the rear should be. If they are rears, you probably have too much rider sag, but if they are fronts, you probably have too little (just a bit though).
Figure 42-50mm for the forks and 30-35mm for the shock. That should get you in a good place to start messing with your Compression and Rebound.
FTR, although these numbers are equal, this doesn't make your bike "balanced". The forks have a longer travel than the shock so the sag numbers set at approximately 1/3 of the travel will be different at each end.
Dave
Yeah I just noticed I made a slight calculation error.30 and 40 for the front sounds really good.
The rear spring seems a bit stiff. You should aim for 5mm static sag (btw 1st measurement is unloaded, then static sag then laden or race sag) if you ride hard, 10+mm if you like it comfy.
40mm race sag sounds good for the rear, but you wonßt be able to achieve that if you crank he spring to get the static sag to 5-10mm.
My rear is quite stiff and I got to say I really enjoy riding it. No complaints. So before you go out and order a new spring, ride and evaluate.
:edit:
hey you edited your post, that´s mean
Aim for 30mm static and 1/3rd of full travel for race sag, that would be somewhere in the 46mm area (I think full 45mm Marzocchi travel is 138mm or similar).
That is good advice for all.Don´t overthink the sag numbers. They´re just that.
If I were you I´d grab pen and paper, ride with the current setup, write down what you think about the setup. Then put in more preload at the rear to achieve either 10 or 5mm static sag, measure race sag (likely too little) and ride again. Write your findings down, then do the same for the front.
After all that evaluate.
Yeah, I'll do that tomorrow, there was a small storm here todayDon´t overthink the sag numbers. They´re just that.
My sag numbers aren´t 100% perfect by the book either, but as I said it rides really nice on the road and while racing. It´s just a matter of finding what fits your riding.
It seems that raising the rear without adjusting the rear preload has made the handling worse, the turn in is a bit slower and more reluctant and also the bike wants to hold its line a bit less. Also, my tyre has something to do with this as well I'm guessing, rear tire is almost showing the steel threads and looks more like a 190/50 than a 180/55We got our taste of the "little" storm here at midnight :abduct:
Let us kow how you fare.
I've ordered a set of Pilot Powers, they did great on my previous bike.One of the things to be aware of is your front tucking in when you raise the rear too far. I don´t know how your geometry looks like, just saying so you don´t get caught off guard.
The tyres will play a significant role in your bike´s handling. What marque and type did you order?
rear ride height is 4 threads showing and front is 1 line showing. I think the sag on the rear is too much, but I have no clue as to how to adjust it. Tried tapping the locking nut loose with a screwdriver and a hammer but it wouldn't budge, and the preload adjuster tool I have is for a SV650S which won't fit this locking nut. Really need to raise the rear somewhat.Drinky, How is the rear ride height and front fork height set up? That made the most effect on turning on my bike. I raised the rear to have five threads showing on the adjustable link. My forks have one line showing, setting the triple tree top in line with the second line on the forks. It has a stink bug look. The best part is it falls into the turns and stays there. I am going to need a steering dampener though.
