Has anyone removed their charcoal canister from a 2017 Hypermotard 939? I went to remove mine & noticed that in addition to the two hoses going to the throttle bodies they T into another hose that goes up near the tank on the right side behind the radiator & it goes into a plug? Maybe it tells it when to Cycle & purge? Wondering if I can leave it plugged in & just plug it up & capnthe two small nipples on the throttle bodies? Every other Duc I have owned only had the 2 hoses to the throttle bodies & the fuel vent....not sure how to remove this one.
