The bulbs are all in an insert that slides in from the bottom of the dash. If I remember correctly, you can get it out if you remove the headlight.
If you have one of the old style metal fuel sender units, I think they weren't ever very reliable.
They work by supplying some power to a thermistor element inside the tank. If the fuel level drops below that element, the temperature of it increases, and the resistance decreases which allows enough current to flow to illuminate the light (this also creates a delay effect so the light doesn't flicker when the fuel sloshes).
Because of this, the system will not work if the bulb is replaced with an LED - I think it would be on all the time if you did that.
The light should come on as soon as the top 1-2cm of the fuel sender unit are exposed to air for maybe 30s? You can see it through the tank lid.
I've had solder connections break on the little circuit board with the light bulbs, so have a close look at that. They must've had the same people solder that who also welded the frames...
Side note, I believe Ducati later replaced these sender units with a plastic float switch that does the same thing, but I'm not sure if it's a straight swap.
