S
screspo
·Guest
Some days ago I installed the kit Termi + injection computer + open airbox + high flow filter.
Because the intake sounded too much I decided to put the original cover of the airbox, leaving installed the high flow air filter that came with the kit.
From that moment the bike has been going fantastic, but a friend has told me that maybe it is going to cause some troubles regarding the proportion of air/fuel... making the mixture too poor and causing overheating!!!
The idle coes fine, the engine is not getting hotter than before, and in that particular case I think that the original airbox is big enough, and with the high-flow air filter the air flows quicker than with the original, so it shouldn't make such a big difference to the fuel/air ratios.
What do you think about it?
Thanks in advance,
Santi
Alicante - Spain
www.elalbir.com
Thanks in advance,
Santi
Alicante - Spain
www.elalbir.com
