After winter hybernation (live in Sweden) and three weeks of work from home (because of Corona/Covid-19) I weigh in at +110kg/242 lbs and the rear static sag (sag with me and my gear sitting on the bike) is 76mm/3 inches with maximum preload and I need a stiffer spring or loose a lot of weight...
Does anyone know if the rear spring on a 2019 MTS 950s (or 1200/1260s) can be changed without interfering with the Skyhook system or am I stuck with what I have?
If it cannot be changed my only options will be to change to a base model without the Skyhook system or live with the extremely soft (and annoying) rear suspension.
