1 - 7 of 7 Posts
I want to change the 50mm exhaust on my 998R with a 54mm.
Do you have tutorial with pics for the bolts on the rear cylinder ?
Mayor of Simpleton
They're just studs and copper nuts (w/an exhaust gasket). What's to understand?
No surrender
Je connais un mec qui à fait cette modif Dominique, si çà peut t'intéresser
en fait, je ne vois pas comment accéder aux 4 boulons qui tiennent la ligne sortant du cylindre vertical.
Je pense qu'il faut enlever le réservoir pour y accéder plus facilement.
Pour le cylindre horizontal, il faut je pense enlever le radiateur d'huile.
Si tu as des astuces, je suis preneur.
Excuses me, I speak French because Flo996 is French.
No surrender
French
Je lui ai poser la question, je te tiens informer
English
I have him(her) to ask the question, I am anxious you to inform
Mayor of Simpleton
Remove the rear wheel for better access. Then just use socket extensions and joints as appropriate to clear the header and shock. It's not difficult--just get everything loosely assembled and sprung so the joints can sleeve together before you tighten all the nuts and bolts.
1 - 7 of 7 Posts
