Humm, will try to clarify.
Roll your bike rear tire around clockwise from the chain side. The top portion of the chain stays tight and the bottom has slack. Place a piece something behind the chain with markings, this can be a piece of carboard like I said, or a ruler or tape if you can get it to stay in place.
Push up firmly on the chain (slack side on the bottom) and continue to rotate the tire until you are at the tightest spot. Meaning the chain has the least amount of give/slack. That is the measuring point you are going to use.
Mark that point on the center of the bottom portion of the chain right between both sprockets.
This is the portion you will measure with the bike just sitting and the cardboard/tape behind, force the bottom chain up and down and measure how far it can go down an up, this is the slack. This total travel distance is what you are setting. The reason I use a piece of carboard is I just mark it with my pencil.
Whatever works for you.
This total distance is what I said should be around 1.5” But varies slightly per bike.
If it’s more slack than you want it to be, more the wheel back away from the bike slightly and check again; too tight, pull it back into the bike.
Here's a picture of the bike, and what I mean by the middle bottom of the chain. Sorry I'm at work and that's the clearest photo I had on my phone.
And here's the slack that you should be measuring
Hope that's clearer... if not ...feel free to ignore this lol
