1 - 20 of 20 Posts
Last ditch effort because I ship my 2011 SFS to the dealer.
I’ve been dealing with this issue for the past month or so, the check engine light come on and off randomly when I turn the key on, and it would stay on most of the time after I start the bike. 15-20 min into a ride my dash would blink and I would get the error code CAN 38.0, but the bike runs fine. I would turn the bike off and back on and it repeats the same cycle.
I was told it could be a battery issue so I changed the rectifier/regulator and got a new battery, same thing is still happening. Checked all the wire connections and nothing looks out of place....
Any suggestions or ideas would be greatly appreciated.
Bon Vivant
38.0 can is a can-bus communications line error. All of the electronics on this bike run on the canbus system so it could be anything from a corroded plug to a broken wire or heck it might even be a burned out bulb. I wish I could tell you how to chase down the problem. Maybe someone else can chime in on this one? Secret Squirrel?
That's exactly how I'd go about sourcing the problem. If it's a can bus issue first trace any modified wiring that's been done. A tail tidy or even aftermarket turn signals can cause a problem if there's any poor wiring connections. Pinched wires can also cause odd problems. These bikes are delicate when it comes to the can/bus system.
If I remember correctly the ECU ground is further back in the subframe. You shouldn't have to lift the tank.
Don't give up dude
Canbus is no mystery it's just a network over 2 wire between ecu, dtc and dash.
Behind dash it's pin 5 and 12 i would trace these.
Pay attention behind the headlight where the wires moves, good place for a short. The 3 places in the tail i highlighted in the referenced thread could be a good place to look too.
If cabling look good try to unplug dtc module and try the bike.
If you can borrow an ecu and put a map with immobilizer disabled it could be a good test too.
If everything is perfect, this will point to the dash.
But seeing it's part time, my guess is the wiring harness.
I don't know why some say the electrics are special, it's like any bike and will give you trouble if you pinched a wire somewhere, or one rubbed to ground. No you won't have any error for a burnt bulb. A pinched wire will quickly worn it's insulation, and loose wiring too.
Bon Vivant
Don't give up dude
Ricko is right and sorry about the bulb thing I was over exaggerating 0:)
Discussion Starter #10
I did read somewhere that aftermarket turn signals were the cause for the CAN for a couple of people...
I’ve pretty much taken the whole bike apart and will go through every wire. Thanks for the advice everyone.
I don't buy canbus error because of turnsignals. They have positive (+) from the ignition and the ecu gives the negative, but nothing to do with canbus. Unless a bad installation mess with the power supply of the ecu.
Good luck and let us know the outcome ;)
You may want to investigate more on can/bus. These systems are very sensitive to resistance changes. When installing different turn signals a different resistance value can occur. Especially while going from regular signals to LED. That's why on some of the bikes there's a setting for regular and LED signals in the dashboard. Just saying
Also we've seen several SF's go dead from a short after a tail tidy installation. Believe it or not the turn signals will affect the whole system on these bikes.
This is because this made the key/on fuse to blow and it is essential for the engine to run, and to the dash.
Yeah it will sense change and make turn signals flash more rapidly so you know a bulb is blown.
Exact same reason why some bikes have this in the menus, so you don't have to use resistors or a LED flasher relay.
Nothing mystical there squirrel.
What's your day job again? I'm electronic technician and know canbus very well. Just saying
I've been running all led signals for a couple years. No resistors. Blinks fast. No cel or other issues.
Bon Vivant
OK so we've established that the Turn signals are not a part of the canbus system, but that doesn't change the fact that the op has a canbus problem. - it just eliminates one area to investigate. I am no expert when it comes to electrical stuff on our bikes.
I've used a type of canbus in my RC aircraft called X-bus and I know that everything in the bus system has a separate power, ground and a signal wire that connects to the bus controller.
Discussion Starter #19
Unfortunately haven’t had a lot of time to deal with it, the bike is pretty much apart so I can get to the wiring so hopefully I’ll have time to work on it soon...
Discussion Starter #20
Just a quick update, just in case anyone else run into the same issue. It was the DDA cable, unplugged it, everything run files, no more CEL.
1 - 20 of 20 Posts
