Protect your steel tank from rust, carbon and fiberglass tanks from breaking down and plastic tanks from expanding.
Caswell Epoxy Gas Tank Sealer [Motorcycle Tanks - Up To 10 Gal] 1 Pint
Pricing: $44.99
Permanently repairs and seals Steel, Aluminum, Fiberglass and Plastic Gas Tanks. We use it to seal and protect plastic, carbon fiber and fiberglass/ Kevlar tanks from ethanol damage as well as seal leaking steel tanks that have some corrosion.
Phenol Novolac Epoxies are a new breed of chemical resistant materials, able to withstand permanent immersion of many harsh solvents, fuels and oils. This Epoxy has much better bond strength than single component products, with strengths of up to 3000 PSI, and this higher strength reduces the need for a clinically clean surface, as the epoxy actually prefers to bond to a rough rusty surface. Our new phenol novolac is more thixotropic, which means it 'hangs' on the tank walls during the coating process. This gives a thicker overall coating. There is more volume of material in the kit to allow for this.
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for the deepest discounts on ALL items . Look for memberships and choose the membership type that fits you the best
And how well will it work for those bikes that the fuel filter and fuel pump are inside the tank?
We remove the fuel cap, fuel pump and filter before we apply Caswell.
Most Ducati tanks have fuel pump and filter inside.
-M
