1 - 7 of 7 Posts
Sophomore Member
Do you have the stock carbs? I'm not sure about cables for those. If you have the FCRs, you will want to buy Motion Pro throttle cables.
I have a set I could part with. But, I'm thinking Motion Pro will likely have what you need or at least can make some.
Reactions: RockAZ
I don't know if they will stock them. They may ask you to send in your old ones to duplicate them, but they'll make them for you.
I took it as an opportunity to learn how to roll my own. It's easy enough once you get over the anxiety of it. You can buy full kits and supplies from Venhill. You just need to source a cable crimper, a soldering pot and lead solder, I got these from Amazon.
Reactions: Hot Air
1 - 7 of 7 Posts
