1 - 2 of 2 Posts
Hi All, am I right in thinking that the forks fitted to the ST range (ST4 to be precise) are the same as fitted to the SSie?
If so, will SSie stem fit the carby headstock?
I have some forks from a 2000 ST4 kicking around, the tops are 50mm but I've got a feeling the bottoms are 53 wheras the carby bottom is 54 I think? I thought they might be a nice upgrade to my ageing '91 Showas.
Thanks in advance.
headstocks are the same, the stem will fit.
ST forks should have 50/54mm, just as the supersport forks,
superbikes got 53/53mm
cheers.
1 - 2 of 2 Posts
