Resident Raggamuffin
Carbon is of exceptional quality as well as fit. Installed in minutes using the supplied epoxy syringe. I'm lame in that I did not remove the original inserts so they're not perfectly mounted (going to have to fix it!). Anyhow, I like the look especially against the rear number plate (decal, ebay).
Thanks again, Shift-Tech!
MODERATORS: i was able to post this without putting the words Shift-Tech in the Title/Subject Window....is that why i haven't been able to post? Or is that just a random occurence? Also, Why don't i see "DELETE" in the EDIT section?
ps: figured it out...you can only use so many words/letters in the Title bar
Enjoy
