this is the one i have on my 01PaulST4s said:Just curious, on the feathercarbon site, which tank cover is the "old" one? I'm assuming that's the one I need for my '02 ?
DucatiST2Rider said:this is the one i have on my 01
I also had to modify the key hole slightly, also glueing the rubber to the carbon was a pain in the assdharhay said:I bought and modified the one that has a closed hole on my 03 ST4s. I cut the portion out with a fiber wheel that you would use to cut steel. Then I lightly sanded the edges.
If you have the tools at home, it wont matter which version you get. Or if you see a great deal on Ebay, they ALL can very easily be made to fit.
Dave Harhay
What rubber did you have to glue to the carbon ?DucatiST2Rider said:I also had to modify the key hole slightly, also glueing the rubber to the carbon was a pain in the ass
i went to home depot and got an epoxy that was for rubber and plastics.. what a pain though, it is still holding so it must have workedPaulST4s said:What rubber did you have to glue to the carbon ?
The rubber that goes around the outside edge.PaulST4s said:What rubber did you have to glue to the carbon ?
