You are correct, without the enricher the bike wont start. I tried giving the bike some throttle before it dies but it did not help. I was assuming this is because then enricher bypasses all the circuits in the carb?
You are correct, when the engine dies it does not hiccup or sputter.
The 14.5v I read from the lithium battery was it off the tender.
As for flooding, when I removed the spark plugs I did see some moisture on the vertical one but the horizontal one was exceptionally clean and dry. I dont understand how it could be flooding if before the bike was starting and idling fine. Last week, the bike started with the enricher but would not idle when I closed the enricher. I had to give the bike a little of throttle or else it would die. Not sure if that is some sort of clue.
