I was going to shut up be hey I'm allowed to change my mind, right.
With the choke closed ....
Remove both spark plugs, squirt a little bit of petrol directly into the cylinders via the plug holes. Replace plugs and try to start it. You will probably have to open the throttle a bit to get some air in and crank it over a bit. If it starts, runs briefly, then stops, your problem is 99% likely a fuel problem.
FCRs don't have a choke mechanism at all. The engine is started by using the throttle pump to inject fuel directly into the inlet manifolds, and blipping the throttle to squirt more fuel in to keep it running till it's warm enough to idle.
