1 - 2 of 2 Posts
I am fitting a IE 900 engine to my carby using the FCRs I already have and wants to finish this buying as little new parts as I can get away with.
Question; I see the IE engine have the bosses for the pick up plate. Is there any reason I cant transfer the Pickups, flywheel and sidecover from the carb engine over to the IE engine?
This would mean I can use the old voltage regulator and the improved coils and ECU I have fitted already..
single phase alt and 3 phase alt are different, as is the crank. someone here did make it work. if you get a 98 - 01 600/750 or 99 monster 900 alt cover it will have a pick up wiring hole.
or get an ignitech to run off the the ie rotation sensor.
1 - 2 of 2 Posts
