I have completed reattaching the wire harness back on my 2000 Monster 750.
I have one connector with nothing to connect it to and I have a fuel sensor wire that has nothing to plug into.
Common sense would tell you that the connector and the plug are a match. The problem is they’re not. The connector is two prong and the fuel level sensor is two prong, but they don’t reach and the plug and connector aren’t a match even if the wires were long enough.
The only way this all goes together is if there is some sort of connecting wire between the two.
I can’t see anything in the part or service manuals that shows this clearly.
If someone could lift their tank on an old monster and take a picture of where the fuel level sensor wire/plug connects, I’d really appreciate it.
Thanks!
