Hi,
I wondered if any can help me with a quick question. Not very mechanically minded :-(
I have an Urban Enduro but was actually out on my Street Triple (sorry, not an official Ducati question) today and was pulling you to a stop at a traffic light and must have forgot to change down. I was in 3rd when I stoped and went to change down and it wouldn’t shift into 2nd, pushed down on the shift level and just no clunk. This has happened before on this, and other bikes every now and then and I usually just carefully start to let out the clutch lever a tiny bit and pull it back in, that’s usually enough to jog something and let’s me the shift down.
I did the same this time and when I let the clutch out a tiny bit and heard a slight noise for just a second (pulled the clutch back in) like 2 cogs very slightly rubbing/skimming against each other, not grinding or crunching or anything. Since the transmission is a constant mesh and all cogs are connected all the time, what was rubbing against each other and would this have caused any harm?
Also, what is the best way to get out of a stuck gear like that?
Thanks in advance for your help?
