According to the Ducati parts manuals, the 748 and the 996 in 2001 had the same part numbers for all four cams. I believe they are the same cams, all the way around, and can be swapped from one engine to another......I believe each cam is specific for vertical or horizontal and intake or exhaust, so you must use the cam designed for that particular use. $500 doesn't sound bad at all....assuming that everything really has been checked out.
