1 - 3 of 3 Posts
I have completed my 12k service and after riding it a couple times It seems I have a leak from the horizontal cylinder. I found oil inside the cam cover, so i removed the rocker pin cover and resealed with gasket dressing "hylomar racing" any way i thought it was fixed, but after short ride found more oil, it leaks down onto the v fairing. It appears it may be the horizontal exhaust cam on the pulley side. My question is do you know what I can do to stop the leak? I was going to just replace the two cam o-rings but I am unsure if that would fix the problem. Can i seal it with gasket dressing even if there is no gasket there? Any help would be appreciated.
Thanks
1 - 3 of 3 Posts
