1 - 2 of 2 Posts
Hey
I just got a caliper rebuild kit from Gotham for a set of 40mm Goldline Brembos and the joining o-ring seal is viton (brown). I thought viton and brake fluid aren't a good combo- Can anyone confirm?
Cheers
Luke
Fluorocarbon O-rings, Viton Orings and FKM Orings
Fluorocarbon exhibits resistance to a broader range of chemicals combined with very good high temperature properties more so than any of the other elastomers. It is the closest available approach to a universal elastomer for sealing in the use of o-rings and other custom seals over other types of elastomers. Fluorocarbons exhibit low gas permeability making them well suited for hard vacuum service and many formulations are self-extinguishing. FKM materials are not generally recommended for exposure to hot water, steam, polar solvents, low molecular weight esters and ethers, glycol based brake fluids, or hot hydrofluoric or chlorosulfonic acids.The Fluorocarbon o-ring is commonly referred to as a Viton o-ring, or Fluorel, FKM, FPM o-rings. We offer a selection of both the standard black or brown AS568 o-ring and the metric o-ring.
DOT Brake Fluid vs. Mineral Oil - and the Winner is.. | Epic Bleed Solutions
DOT Fluid
Certainly the most commonly used brake fluid in use today, due to its wide use in the automotive industry, is DOT fluid. All DOT fluids (with the exception of DOT 5) are made up of a poly-glycol base.
i would say you are right
1 - 2 of 2 Posts
