I have owned my 2005 ST3 since new, and can say I've been very satisfied with the bike so far. No major issues. Never spent a day in the shop for a breakdown. It's always ran well. The key to a good ownership experience is knowing what to look for going in, and staying on top of things.
The 36K *major* service is due, so that means belts and shim check/adjust as well as TPS reset and CO adjustment and TB sync if you want to do it right along with plugs and filters, oil and fuel, and fluid changes. Not cheap so the dealer should make it either part of the deal or substantially reduce the price in consideration of.
It may need its third set of chains and spockets too.
Slave cylinder may need replacing by now as well.
Voltage regulator connectors, by the coolant return bottle, under the right hand mid panel are known to over heat sometimes so you may want to check the condition of the connector.
Consider upgrading the rear shock, the Sachs is not a bad shock but it's a PITA to dial in because it's hard to adjust pre-load, and adding a rear ride height adjuster link, or if upgrading the shock get one with a height adjuster.
May as well drop in a damper kit and stiffer fork sprngs while you're at it.
If it's an S model, forget the above.
There *could* be an issue with brakes juddering that can be resolved with some time and effort and a little money re different pads, buttons or even upgrading to new rotors or modifyig buttons etc.
CHECK THE ENGINE MOUNT BOLTS, especially the rear. If they haven't been checked for correct torque by the PO, make sure the bike wasn't laid down hard. Those bolts have a tendancy to get loose and the engine cases could crack given the right constellation of conditions. It's rare, but it can happen.
Generally speaking, they are good bikes, probably about as dependable as most others; comfy and quick, that will put and keep a smile on your face, and run well for many years if properly maintained.
