Seller only has one black key. Is their way to make some copies without the red key and having to buy a new ecu, gauge cluster and keys? There is an old blog from 2007 that talks about a solution, but I am not sure if it is valid for this model. I copied a portion of the article below.
"... if you have a black key, but no red key, you can make a copy of the black key. You will need a Silca KW17T5 transponder key blank and a lock smith with one of the following cloners (Ilco/Silca - RW2 or RW3, Strattec - Quick code, Jet – Smart clone, Bianchi - Repli-code).
If you want to McGyver it, take the dynamic D sticker off of your black key, push the cross pin out so you can pull the key blade out of the plastic head, then fish out the transponder and JB Weld it on the inside of your ignition housing. Then go get all the $5.00 keys made you want!"
Thanks for your input
Steve
Steve
