My bike is an ST3 2004 model .
I just decided to do the service on my bike so that means cam belts and valve clearances as well as the oil and coolant change.
When I pulled the horizontal cylinder exhaust valve cover I found a piece of one of the valve springs sitting down there .
So now I need to swap the spring there. I looked at Brad's explanation of how to change all the springs which involves total removal of cam , rockers, valves and shims .
I'm wondering if all that really needs to come out? Brad was working on an 851.
Would it not be possible to just extract the shaft out enough to free that one spring, which is on the belt side, while leaving everything else in place? I still haven't found out if it's a pair of springs or if it's all one double spring though.
The other issue is why did it break and whether I really need to replace all of them?
Your thoughts would be much appreciated.
I posted this on the Sport Touring forum as well but thought it might get more attention over here. Cheers.
