1 - 3 of 3 Posts
Ok, whats going on here? How do I get the front off to replace the strap? It seems to be a puzzle, a bad joke...or a magic trick. I thought it would take seconds to fix. I tried to go through the airbox...no luck. Do I have to take the fairing off? The carbs off? Do I twist it? Lol.
easiest to lift the airbox. you pull them through from the bottom. although you can force them through from the top if you grease them up and use something pointy, but not too pointy.
Thanks belter!
1 - 3 of 3 Posts
