1 - 2 of 2 Posts
BREMBO OEM Rear Calipers
BREMBO Rear Caliper P32F- 32mm Piston
$89.06 * FREE Shipping
OEM replacement 32mm piston rear brake caliper.
84mm Mount
BREMBO Rear Caliper - 32mm 32G Piston
$140.07 * FREE Shipping
Side inlet and bleed for better clearance (reversible bleed and inlet allowing top or bottom mount)
84mm Mount
Brembo 34mm Caliper 34G Rear Side inlet and Bleed
$129.87 * FREE Shipping
OEM replacement 34mm piston rear brake caliper.
84mm Mount
Discussion Starter #2
BREMBO Aftermarket Performance Billet Rear Calipers
BREMBO Hard Anodized 64mm Mount CNC 2 Piece Rear Caliper
$1230.00 * FREE Shipping
The best of the best when it comes to rear brake calipers
Featuring: CNC Billet 2 piece design, Titanium Pistons, with quick change brake pads.
This caliper is ultra light weight and requires a custom 64mm mount carrier that is not included.
BREMBO Hard Anodized 84mm Mount CNC 2 Piece Rear Caliper
$482.25 * FREE Shipping
Due to this calipers revolutionary design it provides consistent performance, rigidity, and feel.
Billet 2 piece construction offering direct bolt on capability with most Ducati and Aprilia models.
Optimized for bottom mount hangers.
BREMBO Black 84mm Mount CNC 2 Piece Rear Caliper
$523.25 * FREE Shipping
BREMBO Nickel 84mm Mount CNC 2 Piece Rear Caliper
$586.00 * FREE Shipping
BREMBO WSBK Rear Brake Kit
$1881.62 * FREE Shipping
Designed for the 748-998 series. This kit can be modified to fit other single sded swingarm bikes.
When you demand nothing but the best performance this kit will answer.
Kit contains:
1 Brembo Billet 4 Piston Caliper (titanium pistons and hardware) - 64MM mount
1 Brembo Narrowband 200MM rear rotor
1 Corse Dynamics hard anodized carrier
1 Set of Ferodo FDB2170P Brake Pads
1 Titanium Hardware Mount Kit
This is everything you need to install your WSBK brake system onto your bike.
Pictures installed on our 996R project bike, as you can see it is a very light rotor with a substantial loss in rotational weight over stock:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for access to greater discounts on more items. Look for memberships and choose the membership type that fits you the best
*Outside continental USA, use shipping passwords:
1 - 2 of 2 Posts
