BREMBO Rear Brake Master Cylinder - 11mm Piston [side entry]
$50.95*
OEM replacement on most Ducati motorcycles.
11mm piston offering great modulation.
Black or gold.
BREMBO Rear Brake Master Cylinder - 11mm Piston [top entry]
$52.65
BREMBO 11mm black or gold rear master cylinder - 40mm on center mount holes, straight outlet design & 90 degree remote reservoir fitting. These master cylinders were fitted on many European bikes in the past.
* Outside continental USA, use shipping coupon codes:
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for greater discounts on more items. Look for memberships and choose the membership type that fits you the best
Will this fit the LC multistradas?? Will it help??
Thanks
Thanks
These are OEM replacement master cylinders. It will help if you have defective rear master cylinders - but if you are looking to improve the performance of the rear brake, you might want to check with [email protected] to see if he can get some different brake pads for the MTS.
-M
