1 - 6 of 6 Posts
I'm planning to change out the stock brake master for the RCS19, but I can't tell from looking at it if the stock brake line will fit. The stock master line exits the end, and the Brembo exits the bottom (like a 90 degree fitting would be better). Does anyone know which line would work and/or recommend a particular manufacturer (Galfer, etc)?
The clutch worked with the stock line, but I'm a little more concerned about the brake!
Paul
You will need a new line. You can use online tools to order the correct angled fittings from any number of aftermarket manufacturers such as Hel of Galfer. remove your old line, lay it on the ground. You can then work out what type of fitting you will need on the master end. Good time to get coloured dual front lines. Probably doesn't increase braking but are easier to bleed and look great. I got mine from Hel, all went smoothly.
I can make you a set of lines (2 lines version) just PM me.
1 - 6 of 6 Posts
