1 - 7 of 7 Posts
Hello
I realize this is not really ST related, but y'all are a lot more willing to volunteer info. than many of the other forums.
I recently scored a set of Ohlins forks that came with a pair of four-pad, gold painted radial calipers. The only markings on the calipers are "5J27 4,5" and "5M22+ 4,5" on the other. These stampings are on the bottom.
The forks were mounted on a 996S, but could have had any kind of ducati wheel setup installed. I'm mostly curious if they might be a 1*98 type setup.
TIA for any insight....
I've just had a look at the only 996S parts PDF available on Ducati.com (2001) and it doesn't have radial calipers.
Although you say they were mounted on a 996S, it seems that they must have been retro fitted, and as you say, have probably come from some other bike.
Discussion Starter · #7 ·
Hello, Mark
I believe they are R&T (aftermarket) forks with the radial carriers. But so far I haven't found any part #'s on the fork ends either. So, there's the possibility they are OEM from a newer bike.
They do sport "GMT-Computrack" stickers (a reputable racing suspension rebuilding outfit) so I'm pretty certain they are in good order.
Thanks for looking....
1 - 7 of 7 Posts
