1 - 20 of 27 Posts
Administrator
Working now...
I believe it is OEM on the 2017 Multistrada 1200S and some other late models.
Come in Spinner :)
Hard to believe that Brembo decided to use a cheap and nasty plastic piston instead of an alloy one.
Quality down the pan.
Brembo has been able to identify that the faulty piston is made from a type of plastic (polyphenylene sulphide), and to remedy the situation, an aluminum piston will need to be used as a replacement piece.
Discussion Starter · #8 ·
Ducati included in the recall and specific affected Ducatis identified here.
I smell a free brake fluid change and bleed.
Reactions: DuckMan
Retired Pipe Polisher C2H6O+
I like your attitude. :)
But this has me wondering about the non-OEM Brembo pieces I recently bought.
Yes for the 3 cents they saved on this cheap part, they'll be eating labor ($100 per hour) and brake fluid. maybe they should have their finance people travel around and do the repairs.
Reactions: davy.j and scott
Grrr I’m affected and I ride my bike, 16500mi last yr
It’s in the shop Getting the 18k service done this wk even
And 2 other riding buddies w 1200S w that kind of mileage as well
2015 Monster 1200S
There may be some technical advantages to using a plastic piston... and it's possible it outperforms metal on new bikes. My concern would be that plastic ages and over time tends to get brittle, which means it would likely need to be a wear item that periodically gets replaced even if it IS a better design. I guess I'd rather have something bulletproof that weighs a bit more or is a bit less effective than have another point of failure in my brake system.
Reactions: ncgt1000
Come in Spinner :)
There is no technical advantage to using an injection moulded pps piston, only a cost reduction.
Alloy really doesn't have a half life, pps does.
Brembo have lost the plot.
And fwiw Brembo historically don't supply master cylinder service parts for Ducati's and I can't see that ever changing.
Ducati has been cheapening out
My chain looked like crap early and broke a link at 11k
Decals on tank are no longer clear coated , let alone my decals that were raised about 1/8”, so they pealed from repeated cleaning
Little things that add up to a lot
Discussion Starter · #17 ·
I do not think we can blame Ducati for Brembo's decision to use plastic for an internal part.
Come in Spinner :)
Try buying a master cylinder kit for a 748, 916, 998, 996... they don't exist.
Brembo stopped supplying them after a lawsuit concerning a rebuilt unit.
I searched far and wide for a kit for mine, there are NON on ebay and No Balls don't produce them either.
I located suitable seals in a kit for a Honda but No Balls wouldn't supply them separately and there's only on in each kit and two are required.
Finally got some primary and secondary 5/8" seals that do the job from a local brake parts supplier for about $1.50 for the pair.
You got ripped off :)
1 - 20 of 27 Posts
