1 - 2 of 2 Posts
Will the rotors from an 916/ 996/ 998 fit on a 749/999 series motorcycle?
Are the off-sets the same? Will the calipers line up with the rotors? ??
Has anyone successfully done this?
916/996/998 rotors have 6-bolt pattern, 749 has 5-bolt pattern. Even if the offset was correct they wouldnt bolt up to a 749 wheel. IIRC, the only 996 rotor that have the 15mm offset are the R models
1 - 2 of 2 Posts
