I was about to replace my stock brake reservoir with a 15ml Rizoma billet job. My shop guy says it's OK but the seller says "no" and to stay with at least a 25ml size.
I believe that the brake system does not "circulate" fluid and that the only reason that there even IS a reservoir is to allow for increasing fluid volume requirements as the brake pads wear down. Heat generated at the points of contact will heat up the directly adjacent fluid in the calipers and under heavy, continual braking that heat may accumulate and move through the fluid all the way to the reservoir - but that would only happen in extreme circumstances - if at all. What do you guys think?
