1 - 2 of 2 Posts
I am having some issues during braking. My front brake is causing my bike to shudder terribly once I get down to about 10mph. It feels the same as when rpms get to low for any gear, except my clutch is engaged and the rpms are fine. Any ideas? I am on an 848evo with less than only 2k miles so the brakes should still be in good condition.
way huge member
You probably have un-even pad build-up on your rotors. It's fairly common on bikes with huge, powerful race-style braking systems used on the street. They never really get used hard enough or get hot enough.
A few high speed hard stops might clean them. DON'T come to a complete stop when you do this. That will transfer more pad material to one spot on the rotor making things worse. Otherwise, it alcohol and Scotchbrite pads.
1 - 2 of 2 Posts
